5770S 512mb Crossfire with i7@4ghz
8 Jan 2010
London
Hi just curious how much of a performance hit will I have against the 1gb versions am using a 1680by 1024 resolution.
How many frames should I be expecting with crysis on very high
Forgot to add am using 6gb of ram
thanks;)
Get a 1gb card if you can. Crysis on V High at that res will fill the Vram on a 512mb card so it will cause the game to stutter quite badly as data gets swopped between Video and system ram.
512mb is barely viable as a gaming option now IMO.
Whattt! Where did you get them cards for £140? :O
Thats bloody mental, it will outperform a stock 5850 in most games and come close to a 5870. The non crossfire games though it will lagg behind the 5850
I only got a 512 meg 4870 as I got it for around £35 :P
However, even at 1440x900 I still run into what I think are V-Ram problems... Especially on Crysis; I can't turn AA on in that and still run at max settings.
Modern Warfare 2 also takes a nosedive from AA... not sure if that's the V-ram running out as I can't check it due to being on Windows 7...
But yeah, 1 gig ***, no point even getting a 512 meg card unless you get it CHEAP :)
Not your card as I can run modernwarefare with a gts 250 512mb with x2 aa on 1600 by 1000 with no dips
