Can an OC HD5870 beat a GTX 480??
no amount of overclocking will help the 5870 to beat the 480gtx:
Please do not hotlink images. If you wish to include images in your post, please save the appropriate images to your computer and then upload them to a hosting website such ImageShack, Photobucket, TinyPic etc. Thank you.
the 5970 can barley hold its own against the 480, so the 5870 has no chance.
Cyber-mav's post is a cheap shot.
You could cherry pick results at specific settings and resolutions to show that the 5870 beats the 480GTX without overlocking. The 480GTX is approx 10-15% faster than the 5870 on average, no-one is denying that. The 5870 is easily overclockable to those levels.
Jesus, I have a 480GTX on order so am in no way in the red camp, but I don't feel the need to bolster the green team with BS.
Yes it is. read the [H] review of Metro33 performance.
wat are you talking about look
http://www.hardocp.com/article/2010/04/05/metro_2033_directx_11_gameplay_performance_iq/4
480 owns the 5870 with aa on
the 470 owns the 5850
the 470 is using very high settings and the 5850 is using just high and still gets owned.
the 470 has just 1 fps less in avg fps less than the 5870 at the same settings so.
and if you made this abit more tessellation heavy you'd see the 470 fly past the 5870 while waving good bye
its not only hardocp that confirms that the 5870 is useless in metro2033
as you can see overclocking is not going to help.
the OP's question was regarding if a OC'd 5870 can beat a gtx480, i believe he has his answer now. the gtx480 cant be beat by any other single gpu solution on the market as of today, (06-04-2010)
Yeah in this limited, totally non-cherry picked set of benchmarks the 5870 could never beat the GTX 480! No bias here! Not going to look at averages or anything!
I'm not talking about raw numbers, I'm talking about the % performance hit with any form of tessellation enabled, both cards are similar. I would post the link but [H] is banned here from work.
We can all post cherry picked benches ;)
ive looked and worked out the 480 is preforming over 25% better on avg in tessalation than 5870 and up to 40% better at max fps.
according to the H review.
i think its always best to do the sums
this is fake as it is not at max quality
heres a bench that shows max quality
http://www.guru3d.com/article/geforce-gtx-470-480-review/25
there are settings ati players cant enable :P
and shows the 470 matching the 5870 at 60 with settings ati can handle
and the benches are fishy the 470 can match the 5870 on guru3d at same settings and yet here the 480 cant keep up
and since guru3d has never lied about its review ......
Cheers for that, very interesting stuff.
Guru3D are a known "in nVidias pocket" website, so don't believe all you read ;)
