Can't Get Rid Of Trojan Horse
16 Oct 2005
A family member's PC had a weird virus that I've removed, but it has left behind a trojan horse that won't go away. It only shows up when I scan with AVG:
Nothing else picks it up; Malwarebytes, Avast and Spybot Search & Destory (all run in safe mode) don't find it. I ran HijackThis and the log showed nothing out of the ordinary (using the online analyser).
Googling shows others with the same problem, but I can't find a fix for it.
Any ideas?
Any ideas?
Try this
http://www.gmer.net/
I always found AVG gave me a lot of false positives when i used it and in the end went to Avast! I guess i am now either blissfully ignorant of AVG was a bit too keen!
or enable hidden files and folders and go to the path and try to manually delete it, if possible, works with that stupid one on the net that trys to scan your system and then makes you pay to remove its crap
Always switch off system restore before running scans I find a lot of entries stay within system restore. (obviously turn it back on after)
personally i'd reformat. nowadays i keep a clean fresh built image. If i ever get an infection, i am not going to fully trust any av.. i'll just re-store and run the latest updates again.
