- 28 Jan 2005
- Lymington
Hi Guys,
I wondered if anyone could help me with a little problem I am having. I recently changed my case for a Coolermaster HAF932 as my old case was getting a bit long in the tooth. I have transferred the internals, connected it up, but upon pressing the power button nothing happens.
On the Motherboard (Asus P5K Intel P35) the green light is lit up to indicate there is power and as far as I am aware there are no component failures as everything was working perfectly in the last case. I have checked to make sure the front connections (Reset,Power, HDD, speaker etc) are wired up correctly and they appear to be, I have swapped around the order a few times but to no avail. I have also popped the case top to check the wiring to the actual buttons and it appears to be fine.
I only had this delivered from OCUK yesterday so really don't want to have to send it back!
I've had a Google about and everyone suggests checking the front connectors are wired in correctly which I am 99.9% they are. I guess the ultimate test will be to wire in the connectors from my old case to see if they work?
Any help would be hugely appreciated!
