Caporegime
- 13 May 2003
- Warwickshire
So the skip driver buried a 1ft gash in your wife's "driveway" and fled the scene...are you sure this isn't an allegory?
So the skip driver buried a 1ft gash in your wife's "driveway" and fled the scene...are you sure this isn't an allegory?![]()
ReallyI would actually go as far as to say that you would have been liable if the lorry had tipped over for example.
Really
The driver is the professional, as such it his responsibility to decide where he can and cannot do. If he had concerns it would have been up to him to state them prior to dropping the skip.
As I understand it the skip was not arranged by yourself but by another contractor doing work for you? Did anyone tell him where to drop the skip? if so who?
If it was all done by the contractor doing work for you then they are responsible...... if no instruction was given to the skip company about where it was to be dropped then they are responsible...... if however you or your wife told them where to drop the skip then your responsible.
On a side note Skip Lorry drivers are the Maddest ******** on the road, Fact.
Pick the most impossible place to put your skip just to test the driver & still they won't bat an eyelid & just drive through or over things Dump the skip get you to sign then roar off.I like'em.
As the land owner Huddy would be viewed as having a duty of care for those on his property - it would be entirely reasonble for the driver to assume the driveway was safe to use.Really
