More leaked ATI Drivers (10.4 preview?)
Comment removed
oh dear:rolleyes:, getting beyond a joke reading tripe like this in the graphics forum, give it a rest guys, your acting like little children in a playground.
rant over:p
will give these a test out, thanks OP, hope theres some improvement for bfbc2 for crossfire.
for badcompany 2 i found latest beta drivers and open gl 4 fixed it for my 5850 crossfire setup.
Well, the rolling flickery lines are still present, big fail again by Ati, game also froze with looping sound 5 minutes in, this could just be the game though as it's present no matter what drivers ive tried
You are using the April 7th profiles right?
http://www.rage3d.com/upload/appprofile10_3a/ATI_Catalyst_AppProfiles_Apr7.exe
* Battlefield Bad Company 2 Fix - horizontal lines are no longer observed when running an ATI CrossFireX configuration
* Battlefield Bad Company 2 Fix - flickering and black square corruption is no longer observed when running on single card ATI Radeon products
* Forcing on Anti-Aliasing through ATI Catalyst Control Center is now supported in the following titles: Supreme Commander 2, Dirt2, Avatar and Battlefield Bad Company2 (single GPU configurations)
* StarCraft(r) II: Wings of Liberty beta on ATI Radeon™ 5800 products running in an ATI CrossFireX configurations : moving units near the edge of a cliff no longer causes them to fall because the height field is corrupted
Cheers for the heads up on the newer profiles, didn't know that and only just started playing BC2 the other day, will get that installed tonight.
Think will wait for the official drivers to come through before installing them though!
These may be 10.3b altered by an end user to appear to be 10.4s as the opengl and d3d drivers look REALLY familiar. Downloading myself to have a gander
Not sure what to make of these yet. Had a few games of BFBC2 and had my first ever CTD but then was fine for 2 hours so might not have been driver related. Image quality and speed seem pretty good. Looks like it has the opengl 4.0 ogl file in these but then with a newer d3d (which is still 10 builds behind the 10.5 betas)
However, no popup with these in BFBC2 which is present in the 10.5 betas so I'll have to try a few other games and see if they are truly any good.
Is anyone else getting a gray screen with with vertical lines in battlefield bad company? Also makes a funny noise too.
I've just tested these drivers and no fix.:( I've just spent £350 on this 5870 for this, so ***** off.
Try the 10.3b preview drivers, and then the new crossfire/profile update linked in the other thread. That seems primarily aimed at BFBC2, you can't get too ****ed off because a BETA doesn't work properly...it is after all a beta, and NOT an official release.
Also what do you mean by funny noise? If its just a whining, that CAN be normal, although if it's really pronounced from the card, you may have a faulty one, bad caps in the power regulation etc.
Load times are not an issue for DX9. but DX9 does get the annoying spawn lag and laggy weapon screen sometimes. Not sure if this is a ati issue or a dice issue.
Problem is you can't have AA in dx9 mode :(
I'd rather join 10/20 seconds after everyone else just to keep the AA on 4x lol
