My problem and specs are listed below, I basically want to know how to cool my CPU down, I seem to have a lot higher temps than others with the titan fenrir
Room temperature... I don't have anything to measure it, but it is a hot day
CPU temp under prime95 up to almost 90 with about 80 avg, with 4ghz can reach 100 with about 90 avg (temps on full load with prime95)
Idle temps are around 35-45
Foxconn Flamingblade GTi
i7 920 D0 (BCLK @ 170 only, vcore + 10mV to default)
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (currently on sale, running at 1363 with latency 7-7-7-20 @ 1.65/1.66voltage(shows different in some programs)
ATi 5850 (default at the moment, but stable @ 900/1150 stock voltage under 80 degrees)
Coolermaster Storm Scout with 3 standard fans
Titan Fenrir (fan is facing the top of the pc, as it seems coolest in that direction)
Artic Silver Cerimique.. and then added some of the titan royal grease when changing direction, also seemed to help
Also got a soundcard and wifi adapter installed
Software I have installed and ready:
Core Temp
prime95
CPU-Z
3D mark 03(not newer versions yet)
Aegis Panel Ex
For GPU:
MSI afterburner
MSI Kombuster
GPU-Z
GPUTool
Core Temp
prime95
CPU-Z
Aegis Panel Ex
For GPU:
MSI afterburner
MSI Kombuster
GPU-Z
GPUTool
