Arctic Freezer 7 Pro Rev1 Replacement Needed
20 Apr 2006
Leeds, UK
As title.
Looking for a HSF that will tame a E5200 overclocked to 3.33Ghz currently, but the reason for replacement is to get a quieter system instead of a higher overclock here.
The AC7 Pro Rev1 is definitly the noisiest thing in the system, and a cheap alternative thats quiet and will keep this tamed would be awesome...
For cheap not really, the freezer 7 is still the best bang-for-buck cooler (notably better than the stock one). If you wanted quieter then a thermalight with an apache fan will work well, but cost more than double a freezer 7 :)
the newest freezer pro 7 is very good and very quiet ive just built a system with one and i had an original fp7 and its much much quieter
Awesome, thanks for this. Guess this is what it will be then. Its for the missus' PC, and I spend enough on hers as it, not going down the Thermalright route with her PC, thats for my PC
*Idea just hit lol*
Well, I'm upgrading to a Venomous X shortly, I think I'll just re-use the Xigmatek SDT-1283 I'm using currently for my quad :D
