Asus M4A79XTD Evo
13 Jan 2010
Okay so i got Asus M4A79XTD Evo when i upgraded to am3. more so for the ddr3 support then anything else. but now im running ATI graphics with a nvidia for phyx its running both at 8x. what isnt really acceptable..
Any idea's of a upgrade? gotta support 1600mhz ram as standard... thx
Why the 1666mhz ram support.
The ram will work at slower speeds too 1333, 1066mhz.
Unless you have altered the bios settings then it wont be running at 1666mhz.
For two 16x support buy the crosshair asus board.
what cards you using?
16x isnt the be all and end all.
with the pcie 2.0/2.1 most cards get more than enought bandwidth from 8x (iirc, a 5870 only takes a 5% performance hit from 8x instead of 16x)
