Asus GTX 470 & GTX 480
They aren't bad in terms of power usage to be honest, the same amount of transistors on the previous process, would have used more power, and it uses marginally more than a 295, but is quite a bit faster in some instances, which is fair enough.
Its also got comparable power usage to the 5870, unfortunately, thats per transistor and per size, its 50% or so bigger, and about 60% higher power usage.
It would be a decent amount higher power on 55nm, this is the problem Nvidia dont' have worse problems than AMD, the Fermi isn't bad, its got the exact same power usage per transistor as AMD, the problem is AMD is getting 90% of the performance in a much smaller number of transistors.
TSMC aren't great, thats a given, but the idea that Fermi is somehow not a bad design responsible for its own power usage irks me. Next gen will be equally as bad for Nvidia if they insist on using 50% more transistors, for 10-15% more performance, they'll always have a higher power, less efficient part. People seem to forget that the 280gtx, the 285gtx both had yield, size, and power issues aswell, the low end part in each series, the 260gtx, when forced to compete with the equivilent profitable part from AMD, couldn't turn a real profit. The Fermi is no different because its the same style of design, Fermi 2 will have the same problem and they'll continue to blow it until they increase efficiency per transistor.
The 280gtx used something like 225W didn't it, officially 250W isn't bad, but really its 300W, the difference there, the 70W, is because TSMC have got leakage and power problems, the fact that it would still be a very high power card without it, is the main issue.
Have you considered a career in marketing? I think Nvidia have room for you :D
I think its fair to say the majority of this forum know I'd be a pretty bad PR guy for Nvidia.
The thing I'm trying to highlight is too many people are making excuses, TSMC, manufacturing, hard luck, its not, its a bad design, the previous gen was a bad design, and anything based off Fermi in the future will be a bad design.
Something 50% bigger will have lower yields, cost a LOT more, use a lot more power, be inefficient and when you couple all that with a really bad process like TSMC's, which also induces bad yields, high power then you end up with a core you can barely make and certainly can't make at a profit.
TSMC/the excess power is only part of the problem, the biggest problem is the basic design.
Biggest problem is, big core and high power started to be an issue THREE YEARS AGO, AMD got caught, adjusted, and have thrived, Nvidia saw AMD have a problem, walked into it, walked into it again, walked into it again and ran into it at full speed with Fermi. They've had 3 years to adjust, alter plans and come up with a better idea, it took AMD 6 months to go from a 2900xt to a 3870. At some point someone at Nvidia needs to stick their hands up, admit they made a mistake and move the heck on.
Hi
If I preorder my asus gtx 480 you think that I will have the card on 13th? I saw on a usa website that asus push the eta for 14th.
Hi
The only people who will be getting Fermi on the 13th of April will be those that preordered as soon as the links went up, everyone else will be getting it May unless you are very lucky.
Very good point DM, it's a shame multi GPU support isnt perfect then everyone could make multi GPU cards as standard and not suffer nearly as much from these issues.
i did my order on 5th. you think that i will get my card only in may?
Reports say stock will be incredibly tight, my gut feeling based on what I've read and prior launches says ordering on the 5th wouldn't be quick enough to be in the first batch. PM Fatboy and see what position you are in the queue, and more importantly, is there another brand you can switch to that he thinks will get you into the first batch.
Phoned OcUK the day after I placed my order, which was placed 7 min after they went up, I was told I was around 10th on the list to get one of the ASUS GTX480...
And by the sound of forum posts around the interwebz, from people ringing up retailers asking for ETA, no more then 10 of the 480 will show up from each AIB next week per e-tailer.
