Heard bad things about the selespeed ones. Stick to manual.
The TS engines come in 1598, 1742, and 1995cc verity, and are all Alfa.
Yes, the Selespeed can be fun, but there is no getting round the cost if it goes wrong.
Father just bought a late Mk1 156, ~50k, silver and not a mark on it, tan leather interior which looks new, broken selespeed, £100.
Can't even sell it if it goes wrong.
Fiat block on the 16v's no?
Usually its the pump and not the actuator, i had 2 pumps go in 40k miles.
Most of the petrol range sux. They use the outdated Alfa engine which is based on the old Fiat twin cam engine in all but the 3.2 form. Great in its day but doesn't cut the mustard in 2010.
I am far from convinced that modern alfas are really any more prone to serious faults than any other major make.
You may find the 3.2 a bit nose heavy for FWD.
The 2.0 in them is the JTS, they can accumulate a serious amount of **** on the back of the valves if they're groggled. Dad has seen one after a belt failure which had almost enough carbon to just block the ports, valves must have weighed twice as much. Anyway, anecdote aside, that can make a 2.0 seem VERY flat.
what about a more modern car like the 159 or the GT ?
The Carbon build up was usually caused by a **** up in the factory involving poor cam profile on the exhaust valve cam along with poor software in the ECU.
I'll dispute that on the grounds that the cam-locks fitted perfectly, as always.
Edit: And that it's not well documented.
I will have to agree to disagree with you there. Having returned my ex wifes 6 month old 2003 156 Sportwagon with a poor performance our dealer immediately admitted the problem and replaced the entire engine.
Also if you search the dedicatted Alfa forums you will find lots of cases including the engine numbers it affected.
Sorry, WD didn't have the stats for those, but do you really believe that they'd be massively better?
