Can anybody help me with my pc companion query posted above? I really need it but can't find it anywhere!!
If somebody could send me the installation it would be very much appreciated.
You couldnt send it to me too, Did a factory reset and cant find any software on my sd card,I should have it on my work PC. Ill zip it up and upload it tomorrow.![]()
Does anyone else have a problem with wifi? Ours seems to drop off all of a suddenand then wont come back on, when you press the button it does that circle thing and nothing happens. Other times it works without a fight
For some reason, no matter where i am....I can't get a 3G signal. After a week of use the best i can get is edge. My vodafone work handset shows 3g+ next to it right now yet all I can get is edge. Is O2 that bad or have I not set something up right?
Wouldn't hold your breath Shane. I remember waiting months for 02 to authorise their updates for my N82
PS - Did you try out the HTC keyboard yet? Trust me, it is much better!
thanks for that, i'll make sure I keep it safe this time!
Anyone know what level of branding Tmobile use on the X10? Have read through the thread and couldn't find an answer...cheers![]()
