I assume you're talking about the Christian God?
Atheism isn't related to the Christian God, it's the belief there is no God at all.
Wow, who put sand in your panties. No need to get so angry - I was just pointing out that your post was totally irrelevant to the issue being discussed.Well done Sherlock. Just replace the word 'belief' with 'understanding' and you're pretty spot on.
Wow, who put sand in your panties. No need to get so angry - I was just pointing out that your post was totally irrelevant to the issue being discussed.![]()
What about my post was angry? I thought it came across are more patronising/sarcastic.
Still since they used the word 'God', we live in a largely christian country and christianity is one of the only faiths that don't have another name for their higher power/powers it's a pretty safe assumption to make.
Which is why i said 'pretty absolute certainty'.
To the same extent that Richard Dawkins is a 'level 6 Atheist' as somebody said earlier. But part of following Science is that you have to use logic.
There's no more reason that God should exist than there is for a teapot to be in orbit around Mars. Are you saying we should be agnostic about that?
There bloody well isn't, i can tell you now. How about that the Matrix is real?
It's a silly assumption to make. Atheism isn't the belief that there is no Christian God specifically, as Sherlock has already pointed out to you.
Just because you can't answer his question properly no need to be 'patronising/sarcastic' is there.
PS. I don't believe in a God either but if I did you aren't doing a good job of addressing the questions being asked.
No it's a belief, you believe without proof that there is no and can be no god/creator/higher power.
No, i understand that believing in something without proof is a stupid thing to do.
I don't think any atheist at least no intelligent atheist would say 100% there is no God, but simply there is no evidence of one so to so why worship?
nope.
There has been no evidence presented for such a being so to accept its existence would be based on nothing but "well what else could it be?". Again atheism is simply the absence of belief in 'God'. I don't think any atheist at least no intelligent atheist would say 100% there is no God
Isn't that agnostic? Atheism is 100% belief there is no God - that's the whole point?
But you are believing something without proof?
Quick analogy,
I have a coil hidden i none of my hands and nothing i nthe toher.
Which hand is the coin in?
Atheist: Believes it is in the left
Theist: believes it is in the right
Agnostic: Says they don't know which hand it could be in.
that annoying git on here: "define coin"
Picking a side without any proof for either is just pointless.
The problem is that the use of the word "atheism" has had a bit of scope creep of late and now seems to include everyone that doesn't believe in god. It seems to be something to do with the rise of atheism as a movement and a very faith like attempt to bump up numbers.![]()
