2 x 5850 or 5970?
15 Mar 2009
Hi
Im have to buy a new gfx card, the problem is that i cant decide if its going to be 2 x 5850 or 5970.
All the 5970´s still have the stock cooling but less power use maybe?
If its the 5850´s it is going to be one of these:
Powercolor ATI Radeon HD 5850 PCS+ Pros: two free games and good price Cons: Dont realy know there support and the review i read said they use cheap components.
Sapphire ATI Radeon HD 5850 Vapor-X 1024MB Pros: I have 5770 Vapor-x right now, it runs great, and good support Cons: Price is higher and the clock is lower than the Powercolor PCS+
GIGABYTE RADEON HD5850 OC UDV 1GB Pros: It have there Ultra Durable tech, same as my UD5 Motherboard Cons: overclockers.co.uk dont have it :(
The main use is for Gaming in 1920x1080, but im a student so they have to be able to play games the next 2 or 3 years!
My computer : Gigabyte UD5 motherboard, I7 920, 12gb OCZ Reaper, Creative x-fi 7,1 soundcard, 120GB kingston SSD and 3 640GB WD Black HDs
Have any of you guys had the same choise to make as me or any wisdom to share with me?
Ekstra note : My motherboard have 3 pci slots, and with the two 5850´s they will all be used and one of the cards will only have x8 mode, will this make it slower?
There was an article last week about crossfire 5850 vs the 480 on the unlinkable site rhyming with Nexus. They have the 5970 in all the results, so answers your question quite well.
Noise = fractionally higher for 2x5850 [but only for boards with no gap between the 2 cards in crossfire].
Performance = fractionally higher for the 2x5850, strangely enough.
Power usage = Fractionally less for 2x5850
Cost = £50+ less.
From other sites, we know that the performance loss on a P55 board is only 2% from that on an X58.
One other thing to think about that i didn't is when i added a second card for xfire i couldnt use my xfi sound card anymore as it will no longer fit.Maybe your ud5 mobo has more room than my ud3 so do check on that.
If you have the space i'd get 2 of the pcs 5850's and sell the games you don't need to make it even cheaper. The cooler seems pretty good and people are getting decent overclocks on them.
