Aftermarket Remote Central Locking Kits
28 Oct 2002
Shropshire-ville
Looking to get a kit for swmbo's car and was wondering if anyone could recommend anything at all?.
Cheers!.
I know they're available but pretty complicatd to fit - you have to ask yourself if it's worth it.
What sort of car is it? If central locking was available on it, you may be better off retrofitting from a scrapped car, but it's still a hell of a job
Its a 2000 Fiat Brava mate, already got c/l but looking to get a remote kit for her...it'll only be a few wires...
Ah misunderstood, thought you were looking to fit central locking from scratch!
Not sure in that case, although I'm sure someone will be
Done it myself to a gen 5 Celica, Very easy. You can get many alarms out there which have remote central locking feature, You can also buy kits for just doing remote central locking without alarm. You will need to know what signal the central locking needs.
My Nissan had the cheap central locking whereby the driver's door doesn't come with a lock motor, so in order to make it remote locking I had to add a solenoid.
I hope Fiat doesn't do it like that but it's worth knowing in advance.
Forgot to add about that - the shogun was the same but you can pick up a solenoid for less than a tenner from ebay.
