Brand New Lorry pulled across me on a round-about
you mean you didnt know lorries always have to cut roundabouts because they are usually too large ?
nobody to blame but yourself ....
Clarification of what actually happened would be more useful. For example, was she intending to go left so swung out right to get out and then turned left and you had zipped inside? Or something totally different?
Edit - ah I see, so she took the exit and her right hand side clipped you?
Basically I was going left she pulled up next to me and as she pulled onto the roundabout cut across into my lane and caught me with the rear of the lorry on my right side ... was a long non-artic... :(
Basically I was going left she pulled up next to me and as she pulled onto the roundabout cut across into my lane and caught me with the rear of the lorry ... was a long non-artic... :(
Ahhh ok - I see! I guess that she assumed you would have been gone by then, ie. would have been able to pull off quicker and then be out of her way - still her fault regardless, massively annoying.
Get a 404 pictures not found although Photobucket do very nicely welcome visitors from Overclockers Forums.
Hope you manage to get your car fixed soon anyway.
//edit and now it works. Very odd.
Has she admitted liability etc?
She was very apologetic; her company is a large Merc lorry seller they seemed happy to get it sorted ASAP.. so it should be okay.. you just never know how the other party will spin it... no one stopped either as it was a motorway junction
Erm okay, wow these forums got friendly lately.. cheers for the support dude
Don't worry - I think it was actually a dig at others who often try and pin the blame on the OP immediately... ;) I hope :)
I see the OCUK crash detective agency (TM) are out in force again.
I looked at the first picture and thought "Ah that will T-Cut out" then I saw the second picture.:o
Hope the car gets sorted. :)
