you should be taking them to a place where they're careful with them as a given
Its odd seeing a guy carefully fit a tyre with a high level of respect and skill then smack a bloody hammer weight onto the outside.
Pet hate of mine as a cars will come in for tyres and removing the old hammer weights often does more damage to the alloy and leaves a ruddy great mark which couldnt be seen before.
I need to start doing this. The last time i had a flat i almost broke my spanner by having to jump on it at the side of the road. It took me ages to change the wheel![]()
I turned up to a garage 2 weeks ago with my brand new wheels in a box with 4 new tyres.
The guy still ragged the wheels off the wheel balance machine by dragging them off the threaded centre, thus scratching the paint on the inside of the centre.
Some people just don't care![]()
I would have said something.Whats the point in asking, its not like they throw them around unless specifically asked not to. Its like asking a chef not to burn your steak.
This.
Do you guys think that tyre fitters purposely damage property? Tyre Fitting by nature is a very business when it come to preserving wheels, and the risk is multiplied ten fold if you're unlikely enough to get a "tight" tyre and/or have to mount it on a large diameter rim. Sometimes the equipment fails the fitter - Asking someone to be "careful" isn't going to prevent this from happening.
You assume that everyone starts from the standpoint of perfection, they don't and to suggest they are all great and occasionally get let down by their kit, for by implication this is what you are suggesting, is it at best naive. The fact is most tyre fitters are slap bang wallop merchants unless you make them aware that on your tyres you expect them to take a little longer and be more cautious. That way when they drop a wheel, clank a torque wrench against your wheel or bang the jack into your sill because they are rushing they are going to get it between the bow locks and you are going to expect recompense. Rest assured when my tyre shop works on my car it's the manager and an inspection afterwards and in turn I reward them for going over and above.
Only Nub fitters stick the weights on the visible side.
