The Logitech G11 Gaming Keyboard :)
haha cheers for the help lads/lases (who ever you might be).
I only asked about the wrist pad because i had seen it in other pictures and i will probably use it as at the mo' at my dads im using a standard dell media keyboard with the wirst pad, and i do really really well on cod4 and counter strike, and the fact i can rpogram the buttons, will be cool. However this being my first gaming keyboard, i will probably buy a newer more professional grade one later when i get the dosh :)
Cheers for the halp, and it arrives sometime tomorrow :P
lol first question about this keybaord? why doesnt my main enter/return button work? like i have installed all the software that i got with it but the main enter key would respond, so i had to either click the search button my self or use the other enter key, any problems?
Sounds like it maybe a faulty unit? The keyboard should work fine without any software installed.
ye just maybe it is, but i have already used the keyboard, should i get in touch with them and tell them the problem, if so i will do it now because it was brand new and everything.
oo it works, but i had to press so hard on the button...
did a small experiment on the button, at first glance it looked mishaped like faulty but then i began to press it like 5 times and it clicked back into its original position so its all sorted now, ty for help anyways.
Anyone tried a Razer Tarantula?
I have a Lycosa now but its getting on, want to try something different.
This is the best keyboard I've owned, after about 3 years of use, the W key isn't quite as responsive as I'd like..
Replaced it with a Sidewinder X6 to mix things up a bit, I miss the anti ghosting of the Tarantula now and again.
Razer keyboards are awesome, but they mess up your typing on other normal keyboards.
