how do i load the overclock?
29 Mar 2010
morning guys, my antec 1200 ultima vanquish just arrived and its very sexy!
how do i load the overclock though?
its still i7 @ 2.8ghz ?
theres a looooooooooooooooooooooooooad of fans on this case aint there!
I dont know what motherboard you're using but in the bios, press the f8, f9, f10, f11 or f12 key (not sure which one, check the manual) it lets you load a profile then save it and exit
When you first power on your computer keep tapping Del until the Bios screen loads.
Once in bios hit F12 it should bring up your bios profiles, Load the OCUK profile then hit F10 (Save and Exit) and boot up your PC.
Or you can go back into your bios and check if your Overclock has been applied.
cheers guys, appreciated.
fans are quite noisy aint they on the antec 1200 even on the lowest setting
