ATI HD5770 1GB & Asus P5K Premium Question
13 Nov 2006
Solihull
Hi All,
I am looking at purchasing the HD 5770 to replace my aging ATI X1950XT. I have noticed that the new card supports PCIe 2.0 so will it work with my Asus P5K Premium (which I believe is PCIe v1)? If it will work any suggestions on a particular brand to go for? XFX pre overlcok GPU and mem, most of the others dont. Would it be worth saving a couple of quid and overclock it my self?
Also can anyone recommend a good third party cooler for it as I know that the stock coolers are generally pretty crud in comparison.
Many thanks,
Ross
Theres currently no 3rd party cooler that fits the asus 5770 and even if there was it's struggle to match the vapor-x with the same profile. Save yourself the hassle and just get the vapor-x, just plug in and works :)
The Vapor X cant be overvolted! They have removed voltage tweaking entirely off the thing. The cooler on the Asus one is already a really good one, just like the Vapor X one.
