What are these please?
14 Jul 2007
Hi there,
Recently bought a corsa sport and I'm curious what this and this is.
The first one i press the button and the light coems on bt I don't notice anything different. The other I have no clue what that button does or what looks like a speaker is.
Many thanks!
The passanger side mirror was cracked, so I bought a mirror you stick onto it as I don't know which specific one I need to buy to replace it (as it's attached to the back), I'm guessing it wont effect it?
So the button at the top is for the alarm?
Many thanks for the replies.
The button, due to it's location to the sensor, probably disables the interior sensor, so when you set the alarm you can have the dog inside without it going off. :p
First one definitely heated mirrors, same as in my old Astra, they stay on for a set time and turn themselves off (or go off when you turn off the ignition), you can't turn it off manually.
No idea on the 2nd.
