[TW]Fox;16357776 said:To be fair both of these cars are from the same generation - so inside a 2003 M3 with 50k on it wont feel any more 'tight and modern' than a 2003 M5 with 50k on it. Infact the M5 is a more 'solid' place to be with better build quality.
I totally appreciate build quality is probably not on the OP's agenda really - and both are well built - but I don't think it's fair to say that the M3 feels modern whereas the M5 doesn't. They are both previous generation cars with more similarites than differences.
There was, remember, only a year between the launch date of the M5 and the M3.
Yes, but you can buy a 2006 M3 with the OP's budget...
[TW]Fox;16357809 said:Whereas the M3 is an 'exotic' precision instrument if you like. It wont cruise like an E92, it's more dated inside, but on the right road, in the right mood, it's just a better car.
[TW]Fox;16357754 said:Yes you can, but it will be a 335i SE and not a 335i M Sport. This means it wont have the M Sport bodykit and unless you get one with the Aerokit (Which looks stunning but is very rare) it can look rather ordinary. The 335i SE does, however, have Sport suspension, Sport seats, Xenons, etc etc all standard so the driving experience is of course the same.
335i M Sports are the wrong side of £20k at the moment - so I'm waiting.
Those are 4 very different cars...
Have you driven any of them?
£18k buys a superb late (2005/2006) e46 M3 or even an M3 CS. I average 25mpg over a similar distance commute (26 miles) in my M3. Comfy over long distances and can be devastatingly quick on the twisties - I've had mine nearly a year and still cannot get over how much fun it is to drive.
Additionally (and quite importantly for me) you get the option of an SMG gearbox in the M3.
I've not found the 2 doors to be a problem at all (previous two cars were 4/5 doors). What you do get is nice big coupe frameless windows which are a nice touch.
It also looks like this:
You're right, build quality isn't really a major concern. I want something that is fast, exciting to drive, easy to live with and comfortable to drive to work and on long trips; but I want it to feel alive when I take a back road or take it to the 'ring once every year or so.
Seems like it's near impossible to find an E92 in a decent spec. I've been looking for a 330i and cant find the spec I want for love nor money.
Those are pretty much bang on the reasons I chose my M3 over the competition. You really need to get a test drive/ride in one as I think it will suit your needs down to the ground. You also have the budget to take your pick of the crop.
Another bonus is that there are so many e46 M3s sitting on the market that you can draw up a spec list and wait for your one to come along (took 2 weeks for mine to pop up).
Possibly, but the 335i Sport itself seems to be rare, let alone having a pick of the spec/combo you want. On the other hand, buyers market if you really want a 320d!
