- 27 Mar 2004
- England
I currently have a router downstairs, where a desktop and laptop is connected. A CAT5 cable then comes around the side of the house into my room.
Under my bed is an old Speedtouch 510v4 which I have been using as a switch for years and it has done a good job. Problem is I need more ports, 4 more to be precise.
I was thinking of putting this new switch into the attic, re-routing the CAT5 that goes into my room from the router into there and then feeding the cables down into the rooms.
If I needed 4 network connections in one room I would need 4 individual feeds from the switch for these devices? Thats right isn't it?
Who makes decent switches?
Cheers.
Cheers.
