£1000 system ideas - games/photoshop
27 Jan 2005
Versailles
Looking, again, for a good spec of a pc mainly for games, WoW, Eve, MW ect and some photoshop time.
So, i dont need a screen, but need the rest, also keeping away from gigabyte after my last experiance of them cost me a fair bit of money. So, Asus M/B please.
Rest, as long as it works good, ill be happy.
TYIA for any ideas.
ColiN
i7 930
Asus P6X58D (though u can get cheaper ones if u don't need Sata III)
5850
should be a good baseline
EDIT: if only u didn't hate Gigabyte, the EX58A-UD3R is the best value for money board out there
Last gigabye board cost me a bill of £100 and I ended up without a PC too. So no Gigabyte for me.
But thank you for the info, will see what else I can get in the case, when I decide which coolermaster case to get :)
from what i gather, the samsung F3/WD caviar black seems to be the drives to go for. looking at 1tb, the F3 is just ove a tenner cheaper, so id go for that one.
power supply wise, i think the OCZ modXstreams are really good for the money. id take the 600w version. if you're thinking af going crossfire at some point, then something more meatier like this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-202-CM&groupid=701&catid=123&subcat=1103
dont think you can really go wrong with the coolermater case, or the 5850. i think the i7 and asus board mentioned there is a bit out of budget (need tri channel ram, x58 is pricey etc).
i would say go for an i5-750 or a phenom 965. the phenoms a bit cheaper, and tends to work just as well in a budget or extreme motherboard. the i5's a bit faster and tends to clock higher.
Here's a i7 system.
LANCOOL dragon-lord K62 £84.99
WD black 1Tb sata 6Gb/s 64Mb £84.99
SAPPHIRE HD5850 vaporX £247.98
OCZ obsidian 6Gb DDR3 £119.98
INTEL i7 920 retail £197.99
GIGABYTE GA-X58A-UD3R £156.98
ANTEC new truepower 650W £86.99
Total £979.90
for just the tower bit (i dont really know what good/bad with keyboards/mice/speakers) i would go with:
then add either:
an Asus M4A79XTD Evo with AMD phenom 965 for a total of £777.71 inc p+p
or
an Asus P7P55D Intel P55 with intel i5-750 for a total of £812.69 inc p+p
about £150ish should be put towards decent peripherals, a decent cooler and possibly a sound card.
^ hmm I though maybe an i7 would be better for photoshop but I guess i5 is all he needs, that i5 build above is a pretty good shout
well a grand for a whole system -screen methinks would struggle a bit with an i7. I left it pretty cheap, so th OP can play with it a bit (ie with the money left over, first thing i might consider is slightly better RAM, second thing a more beefier PSU etc)
He said he doesnt need a screen so i think i7 spec should be ok.
How's this.
Gskill ripjaw 4Gb DDR3 £99.99
INTEL i5 750 £164.98
ASUS P7P55D-E £130.99
OCZ ModXstream 600w £59.98
ASUS HD5850 £224.99
SAMSUNG F3 500Gb £44.99
SONY AD-7240s £15.99
COOLERMASTER CM690 MKII £89.99
CORSAIR NOVA 64Gb SSD £152.99
total £984.89.
Latest version of the 690 case.
Not a Gigabyte board in sight.
Sata 3 and usb 3.
Fast SSD and enough harddrive space.
New adobe (cs5) is useing nvidia tech and as much ram as you can get adobe them self recomend 12gb if possible (I read) but i think thats more for after affects etc.
But yeh something like a i7 920 6gb ram and a 5850 sud do nicely.
