I'm considering installing this for PS3, looks quite interesting but I'd imagine a lot of people will end up with the same teams if it's like I think it is![]()
Can anyone explain what this is and how it works cos ive seen it mentioned before and i might be intrested![]()
you basically started off with a bogged standard bronze side (Players rated between 37-64). You play games and comps either on/off line to gain coins. With the coins you can buy packs which contain a mix of players, contract/fitness/morale cards, kits, stadiums, coaches etc.
You then use these cards to improve your team. They is also a trade centre where you can buy these cards as well.
Ah right thanks sounds good, how much is it to get started?
