application install: install package failure
8 Jun 2006
Hertfordshire
Guys
I have had a few BSOD in BC2 and it appears to be graphics driver related so I have triend to update from 10.3's to 10.3b's and I keep getting "application install: install package failure" at the end of the install, I have uninstalled numerous times with ATI's manager and even used driver sweeper to clear everything but when I go to install again I get the same error??
Really beginning to bug me :(
Can anyone offer any advice please?
Thanks
LOG -
Catalyst™ Install Manager
Installation Report
04/15/10 09:15:23
Hardware information
Name ATI Radeon Graphics Processor
Manufacturer ATI Technologies Inc
Device ID 0x68b8
Vendor ID 0x1002
Class Code 0x030000
Revision ID 0x00
Subsystem ID 0x2990
Subsystem vendor ID 0x1682
Other hardware
Existing packages
Microsoft Visual C++ 2008 SP1 Redistributable
Packages for install
Catalyst Control Center
Final Status: Success
Version of Item: 2010.0325.407.5472
ATI Catalyst Install Manager
Version of Item: 3.0.765.0
ATI Display Driver
Version of Item: 8.712.3.0000
HDMI/DP Audio Driver
Version of Item: 7.11.0.7703
AVIVO
Version of Item: 10.12.0.00325
HydraVision
Version of Item: 4.2.152.0
AMD Drag and Drop Transcoding
Final Status: Fail
Version of Item: 1.0.20
Other detected devices
Device ID 0xaa58
Vendor ID 0x1002
Class Code 0x040300
Revision ID 0x00
Subsystem ID 0xaa58
Error messages
Application Install: install package failure!
I had the same problem
I solved it by (after uninstalling ccc etc) going to the control panel, and choosing uninstall programs.
Look at the list of programs if you have 2 Microsoft Visual c++ redistributables then uninstall the latest one (usually the x64)
And then reinstall the latest drivers or the drivers you want.
When you choose the directory to install to it'll say "ATI Technologies", remove the "Technologies" so it matches the default directory it extracts to.
whoops maybe I've given the wrong advice.
But my problem was similar, and it's to do with the error message "INF file not found" coming up during install and the whole package (driver and ccc) not being installed after.
Will look at this thanks ;)
I tried this fix after a google and had the same issue :(
Just tried this and no joy still get the same error :(
Any body else have any ideas please?
Thanks
EDIT: Just found this in the event log - Product: AMD DnD V1.0.19 -- Error 1904. Module C:\Program Files (x86)\Common Files\ATI Technologies\Multimedia\AMDMFTVideoDecoder_64.dll failed to register. HRESULT -2147024770. Contact your support personnel.
Right after lots of reading and mucking about I have carried out a custom install and unticked:
- HDMI/DP Audio Driver
And
- AMD Drag and drop Transcoding
And the 10.3b's install without and error :)
Just hope they fix my BSOD after all this
Hope this helps someone else
