TV wall bracket urgent help!
Is your tv bigger than 32" and does it weigh more than 25kg? If so don't buy it if not get it and use it, if anything failed I doubt they would pay for the TV as they would probably say you have mounted it incorrectly.
It's 32" and my dad purchased it for me that's the problem.
I'm going to take it back and get a refund and buy the one from M form
I'd also recommend M Form, I used one of their Wall mounts for my 42" plasma, and once if was secured to the wall (using some ridiculous massive bolt things rated at 250 kg each) it certainly won't be going anywhere, and the actual mount itself is rock solid, a great product!!!
try it and see if it's any good.
but don't forget if it's bad then you will have to drill more hole's for a better bracket.
my personal choice would to get a better bracket for future upgrades.
entirely up to you.
Check this Lorenzo Porsche Triple Cantilever Arm up to 37" £34.99 Very solid, i use it for 32" LCD.
Or cheaper one wih less movement Lorenzo Porsche Quad Cantilever up to 37" £29.99
Yeah, they're ace!
We used all 12 coach bolts on ours, and they're epically long and wide.
42" Panasonic Plasma + Me Hanging off of it and it didn't budgea bit!
