win7 re-install again (want everything back default))
2 Aug 2006
Elloughton, UK
is there anyway to re-install my win7 64bit ( have original) without going through the activation thing, just my ssd is clogged up and running slow i want rid of all the rubbish and want a total fresh install ( full format stype ) is it possible or will windows say i have allready registered it.
i switched things off and on in reg i cannot even remember and just want to have a fresh install with every thing back at default, or is there some way to reset common settings back to default ?
or officially do i need a new copy?
As above, you should have no problem reactivating. At worst you will have to go through a 5 minute conversation with a robot over the phone, but that is highly unlikely.
If it won't activate just use the phone number it gives you , it automated and just follow the instructions. ( you use you'r phone to enter number etc).
