- 10 Nov 2003
- Surrey, by the river
Don't forget transparent lacquer spray to protect the shiney new paint job.
[DOD]Asprilla;16373354 said:Don't forget transparent lacquer spray to protect the shiney new paint job.
fortunately no rain and no wind, soooo
*snip*
Cycles have to have front and rear brakes by law to ride on the roads...you guys must be in agony using those off road
MW
Not quite right. Cycles must have 2 means of stopping. So fixed wheels can legally get away with only a front brake because the rear wheel can be stopped by the cranks.
Just found this genious brake on bikeradar forums:
I can't get my head round what the advantages of 'fixed gear' would be, can you enlighten me please?
[DOD]Asprilla;16380992 said:I've not followed that beyond the first page, was it deemed to be a good or a bad idea?
[DOD]Asprilla;16382036 said:Ah, I was reading the thread about it in the commuting section. I don't think any of the fixers in there were much impressed, especially since a chain break removes all your braking ability - single point of failure kinda makes having a brake a bit pointless.
Pump mounts?!should have took the pump? mounts off and grinded them clean though !
If you mean the forks, they're being sprayed a different colour, just primed them at the same time.
Pump mounts?!
Oh right yes, well I'd have had to cut them off. Suppose I could.[DOD]Asprilla;16390464 said:I think he meant the pump mounts under the top tube; very old school.
