Devices that don't support WPA2
24 Jul 2004
Devon, UK
Having recently purchased a DGN2000, I today came to add my PSP to the wireless on it so that I could access PSN.
I went through the wireless settings, did a scan and found that my network was greyed out and I couldn't connect.
After a google it appears that the PSP doesn't support WPA2 as it only runs at 11MBit (Wireless B).
I was wondering what the best way around this is without compromising security. I have two laptops (one PC, one Macbook), a desktop, Wii, and PS3 running happily off the wireless at the moment.
Drop to WPA, or try something else?
Thanks in advance.
A cheap, seperate access point and restrict the connection to MAC addresses and only turn it on when you want to use it?
For what it's worth, this is what the DGN2000 offers me in the way of wireless settings.
I wonder what the 'Mixed WPA-PSK and WPA2-PSK' option is? Sounds like it might be useful.
Use any compatible encryption. Just disable SSID broadcast, and limit access to specified MAC addresses only.
Neither of those are very good security measures. Finding networks that don't broadcast SSID is not hard with the right software, since every device set to connect to the network advertises the SSID. Finding out and cloning a MAC address is equally trivial. Anyone who knows how to attack even WEP encryption will probably know how to do this.
From reading about the Mixed WPA/WPA2, it appears that's the way to go - basically the router will connect via either, so I can have the standard devices using WPA2 and the PSP using WPA and all will work fine.
Thanks all. :)
Well I don't seem to have much choice if I want to use my PSP wirelessly - it's not going to work with WPA2 so something's going to have to give... :)
It doesn't really give you any extra security over just WPA-PSK though.
The devices that connect via WPA2 will have the added security though. I doubt the OP will be using their PSP for sending or receiving sensitive information.
Not really, an attacker could connect with WPA and then intercept the decrypted traffic for all WPA2 connections.
Nobody is going to bother hacking a home network with security above WEP though, and they'd only bother with WEP if they were a huge nerd and very bored.
I agree, I just use WEP at home, easier to connect devices to it and who is interested in my home network anyhow ?
*Sigh*
Why take the risk? It's a perfectly feasible operation in organised crime for example, driving around, gaining access, MITMing SSL -> stealing credit cards...
Because it's the difference between using a PSP online and not? In your rare example then as long as you aren't the least secure target then you're fine. Nobody will bother cracking WPA if there's WEP or open APs available.
I agree that people should secure their networks to the greatest extent possible. But I find it a bit far-fetched that an organised crime gang will park up outside his house, hack his WPA network when there's bound to be half a dozen unsecured or WEP networks nearby, then wait for him to make a secure transaction...
