SDD has big drop in windows 7 scores
5 Jun 2005
Southampton
My SSD has dropped down in the win7 rating to 5.9 which is the default standard 7200rpm SATA hard drive speed, i have not noticed a speed drop but wondering if anyone has ideas on this, the performance seems to be there, and i know this scoring chart is not the definitive answer, but clearly it bugs me for it to drop in this fashion..
i have the latest firmware and toolbox for my Intel® X25-M Solid State Drive, 80GB
What does HD Tune or CrystalDiskMark tell you? If they match other results from machines with similar SSD then I would just ignore what the Windows index says.
5.9 on a single sata disk, really?
I have 2 x 80's in raid 1, I get 5.9 and it's a damn sight quicker than a single disk.
it works on seek times so raid doesnt help. its all a swizz to make ppl think their hdd is slowing things down and that they neeeed to invest in a ssd
The maximum for any mechanical disk is 5.9 in the Windows Experience Index, or so I believe.
Incidentally I have the same SSD as Jimlad and Windows 7 has given me a 7.6 for it :D I believe the highest is 7.9 :cool:
you are correct on both counts. i used to have 7.8 now 5.9 - :(
This really. I just re-ran mine to see if an update had broken it and came out with 7.3
Take THAT Windows Experience Index!
lol - i know it was a little OTT,
i think the issue lies with the toolbox and windows7, because straight from a clean install which took 17 mins from start to all windows updates done via USB install to SDD :D
the score still came in at 5.9, so i ran the toolbox which took a few mins to run and bingo back to 7.8, hope it stays that way
What is the toolbox? (forgive my ignorance) Is the drive a G2?
And yeah, USB install rules. Installing Vista/W7 in general is so much better.
im not entries sure, its a G2 and the toolbox does things with TRIM and basically is SSD version of defragger, - someone in the know will correct me, but that was where the problem was for me i guess
