- 10 May 2008
- Manchester
You could say WHY go 32bit when you can go 64bit !!
Ok so going by most responses, the memory really is the main benefit which is important if required in mass by your applications (i.e. CAD, rendering, Virtual Machines,etc). Another point that I really liked was how installing 64-bit OS is more of an encouragement to get the ball rolling on 64-bit apps, if there are way more people on a 32-bit OS then developers are bound to feed the masses over the minority.
.Trentland said:The 64-bit driver issues I had before were mostly with Vista 64-bit. Back when the 4870 was first released, the amount that bugger crashed on 64-bit drivers was annoying a hell. I had a dual boot with XP and it ran seamlessly on 32-bit drivers.
Trentlad said:There were only a couple of other driver issues but it didn't seem worth tackling them again. Sounds like most issues with 64-bit drivers have had enough time to be ironed out now.
Cheers peeps.
The x64 distribution of Windows does have more differences than that, features such as PatchGuard.
Well, there is quite a lot of difference between 32 and 64 bit depending on how you look at it. Microsoft have recommended for a while that the "bitness" of the OS matches the CPU. I don't know how these OEMs get away with selling machines with 4GB of RAM and 32 bit Windows.
Not only a supported RAM increase there is also a greater throughput on the CPU.
Is this true? I haven't really seen anything to back up a statement like this, it's usually been hearsay more than fact.
There is massive boost in performance for any applications that do very intensive number calculations such as encryption. Being able to use 64bit numbers allows for greater precision in floating point numbers for example.
The registers are also larger and more numerous, which means for larger amounts of data the CPU has to do less shuffling around to get the right data in the registers.
You can only use 4gb overall memory, so if you have a graphics card thats 1gb then you can only use 3gb RAM.
vpnclient-winx64-msi-5.0.07.0240-k9-BETA.exeThe only thing that hasnt worked correctly for me in 64bit is Cisco VPN.
Way i see it why would'nt you install in a 64bit operating system, i've used 64bit for maybe 3 years and only had trouble with software and drivers etc for the first few months and that was it.
That is actually incorrect. Although the graphics card does affect this 4gb limit, it does not correlate to the amount of vram on the graphics card.
I thought it was 4Gb limit overall as well, RAM and graphics card memory. Can anyone confirm who is right?
