Corsair HX850 + 12v EPS power connector?
12 Aug 2005
Orpington.
The 8 pin power on the PSU is split into 2 connectors but the second one (left socket) doesn't fit into my motherboard (ASUS P6TD)
The motherboard's connector has a blanking plate over the left hand side of the 8 pin socket, so I am just running with one of the connectors (4 pin).
Is this right.
Running the same board and psu here, simply remove the small plate covering the 4 holes on the atx socket, then plug the other 4 connectors in.
The 4 pin blanking plate simply slides out, long finger nails certainly help to remove it as they can be quite tightly fitted.
I have the same PSU and effectively the same board - it will work.
As setter says, remove the piece of plastic that is covering the 4 pins. Then join the 2 4pin connectors together (they click together) and insert it into the 8 pin socket in the correct orientation - so the hook thing meshes with the catch.
I got it in :D
I don't know why it wouldn't fit when I first built it (yes I removed the blanking plate before) maybe I was too excited to get going.
It's been running with 4 pins for 3 months.
I wonder what the difference will be? if any.
Thanks chaps.
