Poll: ****Official Battlefield Bad Company 2 Thread*****
Which type of game play would you prefer
  • Normal Rush Mode
    Votes: 481 33.4%
  • Hardcore Rush Mode
    Votes: 222 15.4%
  • Normal Conquest
    Votes: 507 35.2%
  • Hardcore Conquest
    Votes: 229 15.9%
  • Total voters
    1,439
I got you earlier, but you were still level 39 :p
Then you got me twice after that :(
Yeah, you get me, I get you back twice as bad :D
@Mouse, mine:
Didn't take me long to reinstall this again, luckily i didn't delete my progress so i still had my rank and everything. Joined a server and got 4 kills within 5 minutes and 0 deaths before the map ended after my 4th kill.
I just needed some timeout from the game tbh.
nothing left to unlock.... :P
Right, should I start working on Recon or Engineer path? Don't like either tbh, but want everything :)
Engineer is easy, just get in a tank with somebody, hop on the turret and keep firing till damage has been done to your tank, repair and repeat.
Recon is tough. If you are lame, join a dead server and grind the m-com stations making sure you're the recon class.
MX518, finally found a reason for being able to switch sensitivity on the fly.... damn chopper turrets are so damn slooow to turn :D
Well, for those of us who don't have the ability to switch sensitivity on the fly, I used this article to good effect. Essentially it means that normal movement as infantry is not affected but when you're in a vehicle (land/sea/air) the scaling on the mouse movements is increased therefore I don't have to swipe the mouse frantically across the desk every time I want to turn 10 degrees.
http://forums.penny-arcade.com/showpost.php?p=13997695&postcount=1684
im hooked on this game, mainly play as assault, but can't ever settle on a gun! i use the m16 is it? but often change when i get rage after losing 1 on 1's which i always do :(
How good is the m16? Because it's the last gun on assault i need to unlock and i still use the XM8 Prototype.
