Triple Monitor Wall bracket - help!!
26 Mar 2010
Hi everyone,
I have just bought 3 samsung 2443BW monitors for an eyefinity setup but have limited space so I was thinking of mounting them on the wall.
Can any recommend a good wall bracket which would do the trick??
Thanks
Thanks for that mate but it says only upto 22inch? I'm looking for 24 and was hoping for a bracket that could hold all 3 together as well as allow the out 2 to swivel to get the full eyefinity eefect..
Have you seen anything like that?
Lol in the UK?
You gota be kidding mate
Only one is this:
http://www.allcam.biz/catalog/product_info.php?cPath=29&products_id=247
But you require 4 x : http://www.allcam.biz/catalog/product_info.php?cPath=29&products_id=697
Thats what i have at the moment, Very nice stand but if your monitors are heavy you will have issues if you move the arms without lossening them first :/
Thanks for that mate.
That looks perfect going to ring them tomorrow.
I really appreciate you sending me that link.
All I need now its a good solid slimline desk that can hold it!
I just don't have the room for a desk that can fit 3 monitors. Having said that I have only looked at the GALANT from IKEA I'm not sure about any others
I've only got about 60cm width to play with...it is frustrating to say the least...
I bought 3 seperate wall hangers to mount my 3 * 2407's. They are the Allcam LCD107. You can find them by searching the rainforest site. I've also got a 42" LG LCD mounted above them that I'm using a seperate gfx card to run.
It's tricky to get them all mounted in the exact positions, but each mount has a great deal of freedom of movement allowing for a lots of different permitations.
Here's a picture below of mine, after I put them up. They are being taken down tonight as I'm having the room totally redecorated this week.
View behind of the 3 brackets. Tooks some fiddling to get them in the correct position for hieght and width.
Taff
problem with single wall mount is that its VERY hard to get them the same height...
the triple stand is better for that
Would agree, mine are a couple of mm out of line. But after the room is decorated I hope a little tweaking and a few washers will help align them.
But with everything it's all about taking the time to prepare and making sure you use spirit levels to put everything in line.
But even with all the preparation in the world the tolerances in the brackets themselves isn't perfect.
The main benefit i see is the ability to have so many different permetations of how the screens are arranged. With a 3 monitor stand on it's own you are limited in the ability to set the screens up in a different manner to the pre-defined metrics of the stand itself.
Taff
Taff, Its very much the same with the triple stand, With the extension arms you can move them as you wish and have a good few verious position...
But if i could actually make a perfect bracket i would have them all on singles on a slideing rail that went up and down the wall :P
