- 25 Mar 2004
- Fareham
Huh? I'm saying you click the class and it uses the last loadout by default, and has a selection of other ones you've saved. Not too different from the class system of MW really but with different ones for each class, saves it from getting too cluttered.
I'm saying it would be more useful/quicker if it remembered your loadout for each class AND weapon, so it remembers for example what perks you use if you choose Assault + Shotgun, or Recon + Shotgun. How often do you change perks with the same class + weapon combo? I know I pretty much use the same perks with each possible combination anyway.
