- 22 Jul 2007
- nottingham
You both have the same card so run vantage and compare gpu scores then you will see if you have cpu bottleneck or not.
Got the card installedEverything at stock. Dirt 2 average 53fps at 1080p everything on Ultra. Using the official catalyst 10.3's. I heard there was a 10.3a, are they better than the official 10.3's?
I'm getting higher framerates in Dirt 2 than I had before and with Ultra settings on now![]()
Great news, I take you are chuffed then?Got the card installed![]()
Its quieter than my 4870x2Idle temp is 44C not tested in game temps yet though.
