Because it kicks 3 cores down..
Why run 3 at 4.3GHZ and 3 at 800MHZ?
Why not? If you don't need the other 3 cores for anything why should worry about them being clocked down?
but your forgetting about the voltage..I can't see how overclocking with Turbo enabled is bad, in fact sounds perfect for an every day overclock. That is if you can set the turbo settings aswell. You could run a 3.8ghz normal clock with 4.3ghz turbo if the benchmarks are to be believed.
Because £100 is nothing
But considering how many games are going to be console ports (hence tricore optimised), boosting 3 up past normal limits wouldn't be a bad thing - IF it's stable.
When considering an entire new rig for £1600, £100 equates to just over 6%. Not really a deal breaker in the scheme of things
i think turbo core only up's the multipler...
if u run a 3.8ghz normal clock with lets set 1.375v, when turbo is on the multipler will go up but the voltage stays at 1.375v so it'll fail.
turbo core is fine for stock because amd as made sure these chip as enough headroom on stock voltage for turbo
These chips are going to have to be good as by my recent calculations an i7 setup would only be around £100 more...
i've read a manuel for a 890fx and the only setting for turbo core is enable/disable. no other optionsI was under the impression that Turbo boosted the voltage aswell? When twinned with C&Q it'd have the same effect though, the 800mhz cores will be running with 0.8v or something like that, then the other cores will be set to the max voltage of whatever is set? So if you set it to 1.5v or near so it is stable with a 4.3ghz turbo, then life is good.
u could set Prime95 to only run 3 threads and then windows task manager to limit prine95 to only use core 0, 1, 2It's also struck me though, how can you test turbo for stability? can you set Prime95 to only run on certain cores? Every combination of 1 core, 2 cores and 3 cores at turbo will need to be tested.
What you have to consider is that most people considering X6's already have Phenom setups of some kind, and its a simple case of swapping out the CPU... not building an entire new rig or moving platform.
which make?Got my 890FX board up and running.
I miss the gigabyte BIOS so much =/.
which make?
i don't like asrock 890FX board because of the bios but the layout of the pci/e's is nice
the gigabyte 890FX board have better bios's but the layout of the pci/e's is bad and only 1 pci slot
ohhhh asus... i don't like either...Asus.
I can't stand the BIOS.
And it also has that LLC BS.
I knew thease X6's were to good to be true i'm so happy i made the correct decision and went for a core i7
What you didn't consider was I am building a new rig so to me £100 isn't really the issue. As for coming from a Phenom set up for the extra performance, if there is any outside of highly multi threaded apps, then the cost for a little more seems to make even less sense. So a small upgrade on the same platform doesn't make sense, neither does switching from an existing platform like i7 or top end i5 which only leaves those considering new rigs or big upgrades.
With that in mind I stand by my £100 difference not really being a deal breaker
Oh and arknor there are loads of people on here that spend much more than this on a new rig and £1600 every 6yrs or so isn't too bad in my mind
