Possible new build help required
27 Dec 2009
Ok I think my old system is dead. Now I have an Antec P180 case, brand new fans including and arctic freezer pro 7, and a brand new Corsair 750W HX PSU (along with my old HDD's). But if my mobo/cpu is knackered then what would your guys suggest. I don't want a pure gaming computer but something cheap and reliable. But is a little more powerful than the old Aus A8n Sli deluxe running two 7800 GTX video cards. Any suggestions
Something like this:
Club 3D ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card £116.99
(£99.57) £116.99
(£99.57)
Gigabyte GA-890GPA-UD3H AMD 890GX (Socket AM3) PCI-Express DDR3 Motherboard £109.99
(£93.61) £109.99
(£93.61)
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) £99.99
(£85.10) £99.99
(£85.10)
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3) - Retail £82.99
(£70.63) £82.99
(£70.63) Sub Total : £348.91 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50 VAT is being charged at 17.50% VAT : £62.72 Total : £421.13
Seeing as I don't have a clue about these things ... are they good quality? within reason I don't expect it to match my gaming system but as long as it performs equal or better than my old:
Asus A8n sli deluxe
athlon 64 FX-55
2 gig ram
Asus 7800 GTX sli cards
then I would be happy
What say thee ??? :)
The system above will beat you current system no probs.
What resolution do you normally play at.
Now a couple more questions ... my old system has XP Pro on it. Will I have to re-install windows again or can I just put all the new hardware in and fire it up?
If your Xp is just 32bit (which i suspect), you'll not be able to use the 4gb of ram, usually only about the 3gb mark. But it should be fine to just use your current install of Xp :)
+ if it was a 64bit XP, then its fine :)
In this day and age is it worth sticking with XP on a system that could do more, or should I upgrade the OS at the same time? I have a Windows 7 install disc that came with my OCUK build, could I install from that and pay for a licence?
So I would not have to re-install windows at all .... that's good news :D
I think you would have to reinstall the Window XP if the new motherboard's different brand from your existing one.
When I was still using XP, I changed from one MSI board to another MSI board, and I didn't have to reinstall the XP. But when my dad move from from one brand to to another brand's motherboard, he could no longer go into Window and require a reinstall.
And yea the AMD Athlon II X4 Quad Core 630 is a good budget Quad Core. Its performance is roughly around the same as Core2Quad's Q6600.
darn it that puts the build price up a bit more .... I really want this build to be a workhorse, for the family, for video proccessing and for downloading 24/7. Now I have my XP Pro disc still, but it's probably not worth using it if I can only run 3 gig ram .... so Win7 it will have to be ...
