I have heard that the stock fans on the CM690 II are a bit naff but how "naff" is "naff". I mean, if I bought the case, would there be an urgent need for better fans or is it something I can live with for a short while?
If I cant live for a short while, I was thinking of kitting my new case out with 3 (as I can only afford 3 atm) either Sharkoon Silent Eagle 1000s (1000s due to less noise, even though I know that they only shift half the air of the 2000s...but do I really need almost 80CFM of air on my fans?) or Akasa Apache Blacks.
I know that the Apaches move more air for the sound volume they give off but they are £4 more each and I kind of like the white fan look of the Sharkoons.
Also one more question, kind of a big one really. My motherboard (Biostar TPower i45) doesnt seem to have case fan connections. Am I being stupid and missing them or does it not actually have any? If it doesnt, does that mean I would need a fan controller to use the new fans? I am used to 4pin molex fans you see.
Thanks
Thanks
