Is it just me that hates the massive red arrow on the 4x scope, it really puts off my aim tbh.
I don't use scopes on any assault rifle personally, if you tag someone, you can see them at any distance, you know if you hit from the cross that appears, so I prefer using magnum ammo which increases the effective damage at range.
Do any of the scopes actually make your gun more accurate or do they just give you a better view? (Like crysis where attaching the laser pointer would reduce bullet spread, and IIRC attaching the x12 sniper scope to an SMG increased it's damage at range
