Free forum worth bothering with?
18 Oct 2002
, Washington DC
Hey all,
I used to host and run my own forum using phpBB, which shut down a few years ago. Basically I'm thinking about starting a new one, but for professional development in my job sector. It needs to feel as pro as possible, but hopefully be free!
I don't really fancy paying for hosting (bandwidth charges used to cost me a bomb), so is there any free online equivalent of phpBB that would allow a similar amount of control and quality?
I'd like the ability for sub-forums, an anonymous forum and also a reasonable level of control to avoid spambots and trolls.
Thanks a lot for any help/advice!
I mean professional in terms of feel/quality (no pop-ups, no ads) and it's going to be free to register as I want as many people as possible. It's not an existing community/forum so again feel is hugely important because it needs to draw (and keep) a good community to it.
Free forum software, some decent ones nearly as good as vBulletin. phpBB and Simplemachines spring to mind.
Free hosted forums, I wouldnt even consider when you can get hosting packages with yearly fees of £15. All the ones I have tried had some form of advertising. Even worse, you are probably treating all your subscribers to a lot of free spam you have no control of, courtesy of joining your forum. Not nice.
So it sounds like free isn't an option then... Who would you recommend hosting-wise then (preferably with a domain name included) that also has a good bandwidth allowance?
UK Based - Vidahost and TSOHost
USA - I use and like Bluehost, but the demise of the £ has made them relatively more expensive that they used to be. Main thing I like about Bluehost is Simplescripts, which is a nicer than Fantastico.
Thanks a lot guys.
Vidahost look brilliant... What do people think between vBB and phpBB? I remember phpBB used to need a LOT of upgrading to keep it secure from hacking etc. - is that still the case?
