Hi guys,
I've just bought an xbox 360 from a friend and I'm trying to think of the best way to connect it to my monitor as it's better than my TV.
I have a 20" samsung pebble, it has a DVI in and a VGA in. My console has a HDMI out and I've got a HDMI to DVI out cable which I was thinking about getting a converter and using the VGA slot on the monitor (I know the picture won't be of HDMI quality). The other solution is to get something like a DVI splitter for the monitor and having both the computer and the xbox connected at the same time to the same port. The last option would be to get a DVI switch box which I could manually switch when I want to use a specific device (although I'm not really too sure on what I'd need for this, or even which one to buy)
I'm not really too sure on what my best option would be here so any information is appreciated.
Cheers
Cheers
