The T1R's I currently have are better than F1 GSD3's, but neither are "right".
Really? I was always under the impression that GSD3s were FAR better than the Toyos?
humm I think i'll try the T1R's next, the PS2 prizes make me weep, thnaks
[TW]Fox;16429903 said:Or slow down.
Also driven on T1R's, an OK tyre and very progressive, though they squeal way before letting go especially on roundabouts.
Don't take the ****, I can't afford the 328i.
I think the bubble sidewall is the issue, but I'd benefit from something stiffer I'm sure, I'll try and hunt for some 17's
[TW]Fox;16429903 said:Paradigm drives everywhere at 100%, nothing bar a racing slick will ever give him what he's after.
Was out for a quite drive today, and I noticed that when the car was letting go mid corner it would slide-grip-slide-grip-slide-grip, in an almost bouncing sort of way. Is this because of the tread pattern or are all tyres like this?
the vredsteins have a stiff sidewall. They gave great turn in on the vectra
I run Kumho ku31s, they have a stiff sidewall. I find them brilliant and when they do actually let go its just a progressive, controllable slide.
