- 1 Apr 2009
Yep, it's another 'pimp my build' thread.
Total is around £1,000. Can you do better for something around that budget (+/- 10%)?
I'm going with :
- AMD Phenom II X4.
- sound card (not creative).
- ATI HD 4850 (as cool and silent as possible).
- 27'', HDMI and DVI, and I like the tuner on the LG (I don't have a TV).
My current config is a Q6600 2.4ghz, 9800GTX+, a Corsair HX 620W, Lian Li PC-A71B. Wondering is the PSU is enough, I think It's OK.
Thanks.
I'm going with :
- AMD Phenom II X4.
Thanks.
Which one? if you have the quad I'd have a bash at overclocking 1st with a decent 3rd party cooler. If you have the Dual core instead stick with your original plan.
