L4D1@2 ARE DEED
12 Sep 2009
hi all hope some one here can help I keep geting disconnected from lfd 1and 2
about 10sec into game this has just started over last week.
My isp is bt with homehub 2 download 6.5megbit upload 0.4megbit ping 57.
OS win7 64 bit pro.
Try re-installing steam and deleting all old game files (be sure to backup to external drive so you can copy them back after you re-install steam) that solved my problem with connection issues. Also you could try going back to the old steam UI if you have the new one, for some reason when I have the new beta UI installed I can't pick up group servers and get connection issues.
hi I have reformated my hdd reinstalled windows all up to date
reinstalled lfd old ui just the same as before updated to new ui
same thing disconnect 24 sec have no brob with enny other software.
hi I think you are right. got a BT TEC MAN comeing on wen still odd that it only started 1
week ago hub is prob full of zombies hope he has got large van.
i had this, and it was the cheapo router that came with o2, a few fixes worked for a little bit, but after purchasing a good adsl router it stopped for good
