Use the on/off switch for the wheel too in future!!!
I've left my cam on ISO 800 before now, the shots can be a bit noisey, but not unusable....
On Nikon you can press the two buttons marked with a green dot, which resets most of the day-to-day settings (eg. ISO, white balance, bracketing) to a known state. I do this before every session -- very useful.
Shooting in RAW is the answer to that problem as you can change the WB in post processingDoing most of my shooting indoors with my daughter (when I get home in the evening) I have a custom white balance setting or indoor tungsten...
And then the odd weekends where it's sunny and I forget to check... lots of washed out images.![]()
I went on a 3 day canoe trip and left my CF cards at home, I wasn't happyWe had some pretty awesome rapids and saw lots of wildlife like herons, kingfishers, deer and cormorants too, typical.
Shooting in RAW is the answer to that problem as you can change the WB in post processing![]()
Never knew that, unfortuantly it seems to set it to medium quality JPEG as well
