any vehicle mechanics/technicians here?
8 Dec 2004
Paignton, Devon
Hi all,
I was wondering if any of you guys know where on my 53 plate (registered feb 2004) OBD2 port is, I have looked under the ash tray where i thought it was but cannot find it.
It's a Peugeot 307 110bhp 2.0 HDI :D
Hi all,
I guess will probably help if you gave us an idea of what car it is? Or does every car built in 2004 have it in the same place? :p
A lot of peugeots i have seen have it in the fusebox, or under the steering column area somewhere (the fusebox is usually here too).
Edit: from what I have found it seems to be in the fusebox OR under the rubber coin tray insert by the ashtray, OR under a cover to the right of the steering wheel on the dash (lower down i beleive)
I'm sure if you phoned a local Pug service centre, they'd be happy to tell your, or at least ask a tech for you.
