26 Apr 2010 at 15:56 #1 Adam18290 Adam18290 Associate Joined 26 Jan 2007 Posts 728 Location Surrey Yo, Can anyone identify the following power connector for this drive? It seems as if theres a notch 3/4 of the way down rather than at the end!? Cheers
26 Apr 2010 at 15:58 #2 smilertoo smilertoo Soldato Joined 4 Aug 2005 Posts 3,364 Custom connector just to screw you over and make you get replacements from them.
26 Apr 2010 at 16:01 #3 Phatzy Phatzy Associate Joined 21 Apr 2008 Posts 1,536 Location Manchester on some laptop there should be a connetor that you just pull from the hard drive itself
26 Apr 2010 at 16:22 #4 godinman godinman Soldato Joined 26 Feb 2007 Posts 8,573 What's the make and model?
27 Apr 2010 at 09:20 #5 Adam18290 Adam18290 Associate OP Joined 26 Jan 2007 Posts 728 Location Surrey its a Toshiba - however exact model is covered by some sticker - HP p/n is 467813-001
27 Apr 2010 at 09:38 #6 lazer46 lazer46 Associate Joined 14 Apr 2010 Posts 513 Startech 12IN MICRO SATA TO SATA WITH SA - POWER ADAPTER CABLE - F/F UK Thats what you need. Google it. Can't post a link here. Its a Micro Sata Connection
27 Apr 2010 at 13:59 #7 Adam18290 Adam18290 Associate OP Joined 26 Jan 2007 Posts 728 Location Surrey Thanks a lot^!
27 Apr 2010 at 14:12 #8 mast3r mast3r Soldato Joined 28 Jan 2007 Posts 2,558 Location Wilmslow, Cheshire thats a new one. thought it was SAS at first.
27 Apr 2010 at 15:02 #9 Dutch Guy Dutch Guy Soldato Joined 18 Oct 2002 Posts 24,560 Location Amsterdam,The Netherlands lazer46 said: Startech 12IN MICRO SATA TO SATA WITH SA - POWER ADAPTER CABLE - F/F UK Thats what you need. Google it. Can't post a link here. Its a Micro Sata Connection Click to expand... Is it really smaller than a normal Sata connection?
