Crap doesn't float on fuel in tanks, it sinks to the bottom in nearly all cases I've ever seen and being as the pump sucks from the bottom it's never an issue.
Logic failure.
Probably gearbox noise, I wouldn't worry.Hi Guys
I thought I would share my current driving woes/excitement for tonight
---Problem 1---
A couple of weeks ago the car started making a mid pitch whine when i hit 40mph and would dissapear at about 50mph (i think this is more down to the tyre and wind noise over powering it). But this is since been getting louder.
Very likely a bottom ball joint, MOT fail if it is.Also ive noticed a knocking noise when going over some bumps and round some round abouts coming from the front left .Any idea what this is? I hope these are associated some how?
Alignment's probably none too good either.P.s. The front left alloy was damaged last year thanks to a pot hole. new alloy and tyre required.
How big a slope, and in what direction?---Problem 2---
Today I thought ill go for a late night session at the gym at work. So i parked up as I always do and did my 1hr work out. Came out to my car turned the ignition and it just sat there turning over. By this time security had come over and asked if i was ok. As i had parked my car on a slight slope leaning towards the drivers side they helped me push it onto a flat spot where I left it and had a cup of coffee. Came back after 10minutes and it fired straight up. So what on earth happened here?
The fuel light had been on and off all the way to the gym but I had driven the car all the time like that and never had an issue. And it drove there perfectly fine.
Quote taken out of context failure!! to make a non existent point.Logic failure.
Hows the coolant level? On my old 306 the coolant was running a bit low and I parked on a slope and this caused the coolant level sensor to think there was no coolant and the engine would just turn over. Pushed it on to the flat and it started right up. I then refilled the coolant and parked back on the slope and it was fine.
